Could someone tell me if a SXR700 redhead will fit and work in a sxv? Or what would need changed to make it work in the viper. Thanks
you would need the carbs, cdi, and pipe at bare minimum. might need whole wiring harness and primary clutch weights as well. look at the sxvenom as that was the viper chassis with the 600cc sxr tripple in it from factory.
bluebandit98
if im correct just buy sx venompipe and can and use all sxr electrical 02 preferably and yes will bolt in with sx venom mounts...
