My sled has been creeping forward when its just sitting there at idle. Whats wrong with this sled? What do i need to fix?? The clutches are clean and idle is set correct, its a 99 V max duluxe
Check how high the belt rides on the secondary. The ribs are supposed to be like up to 1 mm above the edge of the secondary to 0,5mm under if I remember correctly. If it rides any higher, it will creep/squeel.
wheeliemaster92
Check how high the belt rides on the secondary. The ribs are supposed to be like up to 1 mm above the edge of the secondary to 0,5mm under if I remember correctly. If it rides any highter, it will creep/squeel.
yea it sounds to me you have a pretty used up belt and it sitting inside the secondary to much which would make it hit the primary i would buy a new belt if i were you
shaggyzr2
If it were sitting too low in the secondary it would be less likely to creep forward. If it is sitting above the secondary too far pull out the 3 small bolts out of the back of the secondary, there should be a washer on each, remove the washers and put the bolts back in, that will open up the secondary a little so the belt can sit lower in the secondary.
super1c
Super Moderator
x2! Shaggy has you covered. Belt too high in secondary. Is it new?
I will try pulling out those 3 washers and see what happens. It makes sense!
belt has about less than 600mi on it.
super1c
Super Moderator
Thereby a go, new belt. Pull washers till belt breaks in and wears a bit them put them back in.
