Dominicturbo
What is the max height track on a Vmax-SX chassis with 9 tooth driver? I wish use a 2 inch paddle it is possible?
Thank you.
Thank you.
devinzz1
Gota go 8t and remove exchanger protectors.
mrviper700
VIP Lifetime Member
1.75" lug will just fit with 9 tooth drivers, but its tight, you need good power in order to keep the tunnel cleared out of snow. I ended up trimming the lug to 1.625 and it worked better and picked up a bit of speed.
A couple of bucks
Just put in a 1.5 in an 01 SXR w/ 9 tooth drivers. Had to remove the h/e protectors. No problem.
