i just bought a 1985 phazer and it has a psi pipe on it. apparently it is jetted for the psi pipe. id like to put the stock exhaust on it, does anyone know what jets need to change. mains and pilots?
thank you
thank you
sleddineinar
In the tech section, here is the link. I know it only goes back as far as 86, but the jetting is the same over the years on the Phazer. 143.8 mains and 95 pilots. http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
PhazerPorn
I would be open to trading a stock exhaust and $$ for your psi pipe. Please let me know if it would be something youd like to do.
Keep up the research, im following your threads and may use some of ur info on my build!
PhazerPorn
PhazerPorn
