get the vaseline
300.00 to clean the carbs? You have got to be kidding! Listen, all you have to do, is remove the airbox, loosen the big 'clamps' on both sides of the carbs, one on the airbox, one at the reeds (engine), disco the tors wires, throttle cable, and pull the choke right out of the dash. Then, loosen the little drain screw on the bottom of the carbs to drain the fuel, and take the 4 phillips screws out of the botton of the float bowls. Remove the pilot and main jets, and blow them out, make sure there is nothing stuck in there. Thats it, stick everything back in, and you are done. If a dealer charges you more than 1.5 hours, he is trying to take you to the prom, without the prom. We have done them in 40 minutes, on a srx, including changing jetting, and thats taking our time. You better go lay a smak down on the dealer.
