indy
- Nov 27, 2004
upon inspection, the slop appears to be under the engine in the linkage . . . how do I get access to it? what should I expect?
Maim
Super Moderator
easyst way is to pull/raise the motor. if you are lucky the nut just came loose from the tie rod and the threads are ok still.
