indy
- Nov 27, 2004
the switch has been loose (no resistance) for many years . . . is it common to just have to replace the switch? what should I look for and where?
super1c
Super Moderator
Not sure if common but they do fail. If your sure switch is bad just replace and go from there. Easy way to test grips is to check resistance with a meter between the two wires on the grips. If good grip should be good.
I really dont have an answer for ya. But this may help.
If your talking about the switch for high to low on temp control mine is pretty loose to. turns easy. The key needs to be turn to warmer position. You basically have 4 options. The key switch, low to high adjustment, the hand warmer, or bad wire. If it was me I would take a meter and start checking for voltage starting at the wires going to the handle bars and work my way back. until I did not have any voltage. If you have voltage at the grip more then likely the hand warmer itself is bad. I think these put out a 12v a/c
