Now that Yamaha has different versions of the tuner ski, which one would be best for a 2001 sxr? The Viper version looks to have a higher mounting hole. Would this be better for ride height?
devinzz1
Non viper version will just bolt on. Viper uses arctic cat skis.
Unless I'm mistaken the 2015 Viper uses Tuner skis,at least the ones I've seen pics of did.
devinzz1
Arctic cat mounting i meant.
Youl have less problems fitting the regular ones.
Decided on the regular tuner skis with 4" inside carbide and 2" outside carbide. Total cost from local dealer $250.
super1c
Super Moderator
The old ones are a touch wider also. BTV did a write up on this on the 4stroke side and last i saw the regular ones are the ones to go with.
