triple pipes fit w/elec. start & reverse?
fastkrome
Calgary
Just bought a 2002 mm700 w/elec.start & reverse and am wondering if I can pipe it or put a custom can or something on it? I also need to re-jet it because it came from a higher altitude than I'm at.
Would anybody know what I should set the carbs up with at 3000'-3500'? with stock pipe & clutch?
Thank you
I know of people fitting triple pipes on SX chassis sleds with reverse but there isn't enough room to keep the battery in there. Pm me your email and I'll send you the setup sheets for clutching and jetting.
Got PSI pipes on my mtnmax with reverse, no problem... Maybe with electric start and battery there could be some problems..
