justin1620
Hey fellas, does this track still look safe to run? It has some missing lugs which I'm not worried about, but I can see white lines across the track as you can see in the pic. It came off a doo, I think it's a single ply carve, but not 100 % sure. I just don't want this thing to come apart on me at high speeds, we run a lot of hard packed lakes.....what do you guys think......are those white cords across the track ok? It is not "ripped" anywhere. ..could I still get a few more seasons out of it?
shaggyzr2
Looks ok to me, you should see the tracking on my sx...still has the original track on it from 97, that thing should have been replaced years ago. lol
Yeah I'd say your good to go.
dmc413
Only 144 studs...lol
Is there a flaw in the track that your trying to show in that pic? Cause it looks good to me.
if thats a crack/split at the 12:00 position of the wheel, and it looks like it, then the white line will probably be the strength cords showing through. If the lines are also on the inside of the track i personally would not do top speed runs.
justin1620
You can see the strength cords along the width of the track in about the 11 o clock position of the wheel. The lugs are all in good shape but there are about 6 different places where the white strength cords show across the width of the track...I just wasn't sure if this was acceptable to be able to see the fibers running width wise.....
