Mono Shock Mounting Plates
hibshman25
tya
Myerstown, PA 17067
Is anybody making mounting plates that take the guesswork and measuring out of the mono install?
We are working on plates for the RX-1's and wandering if there is interest in something on the two stroke side.
Our plates locate themselves using 4 existing rivet holes in tunnel and the center skid mount hole. Once the plate is located on the tunnel then the plate serves as a template to drill out the tunnel.
Now that season has slowed up I am back on this project. I just finished laying out plates to put a mono into an 01 srx. I am utilizing holes from the center mount bracket as the locating holes for my plates.
Tried to look up the tunnel brackets on various models and years to see which ones use the same bracket as the SRX but it appears that yamaha does not call out the brackets. Does anyone know which years and models would use the same center bracket as the 01 SRX?
I don't have the answer to your question, but am glad to see you are doing this. Thank you.
