lil3incher
Would SRX 700 Carbs fit a VMax SX 700, and also how would A RX 1 Clutch affect The SX
As long as srx carbs dont have tps sensor and are changed to sx jetting specs. Same goes for rx1 clutch just put the sx clutching in it with the tall spring required.
97 didnt have the heated carbs so just block off the cooling lines with rubber plug caps on the carb rack. not totally necessary, but it just looks cleaner. better yet, look for a 98 and up red head and activate the carb heat.
