Does someone have a document that's a little more detailed than the manual to ensure the clutch on my 1990 exciter is adjusted properly and operating per specification?
As long as you dont have any slop, your good to go. The only adjustment there is would be in the secondary clutch. Set to stock is B2. Center to center is 10 9/16 i believe and offset is 11mm. This going from memory. If I am wrong, I expect to be corrected. lol
