First of all, will it transfer weight better than a stock 01 with transfer rods?
Which parts will I need?
http://fiche.worldofpowersports.com...=320&b=25&c=0&d=-SUSPENSION---TORQUE-ARM-ASSY
Will the parts from say a 2006 Vector Mountain fit?
never really broke down the parts, always did it as a unit. personally i think the ride quality and transfer is way better with the pro mtn skid vs the pro action skid. not to mention lighter. similar in design to the cat and poo skids of that era.
if you had the entire skid from the 06 vector mtn, that would fit, but i recall those as 151 skids with the tip up rails same as the 151 rx1. the viper pro mtn from that era was the 144. i know the 144 venture pro comfort skids were similar but the mtn parts didnt correctly interchange.
What if I put that skid on stock MM rails, would it be screwed up?
personally have never tried it. if i had rails side by side for a comparison i could honestly answer. in my mind the rail configuration was different but that was just at a glance, never measured, just installed skids as a whole.
