tripple_tripple01
ok i just found my problem. i thought it was in my clutching but no............my power valves are stucking in the cylinders. funny cause i just cleaned them before snow fell, late october, and only put maybe 4-500 miles on so far. i can only move them by hand maybe a half inch at most, is that normal, do they only move that far???? also i cant get them out either. i usually run amsoil, and recently changer to blue marble, the tank was really really low when i put the blue marble in. any sugestions on how to remove them now and how to prevent them from " gumming up" so bad????? my sled will only pull 72 to 7400 rpm's now and im sure the power valves are the problem
Brad
- May 23, 2003
start the seld and let it warm up, the valve should come out once the oil and crud around the valve is marm. check your oil pump cable adjustment sounds like your running way to rich also check the cable at the thumb lever and make sure it is seated properly in the lever and switch back to AMSOIL
