Help with clutch engagment
SP00N
I have a 99 vmax sx tripple 700. And today when i went out for a ride i noticed that my clutch was engaging at only 2000-2300 rpms.Anyone have any ideas as to waht is causing this? any ideas would be great,thanks.
You should replace your clutch springs if they are the original ones, or at least inspect them to make sure your primary spring is not broken. May want to do a full inspection of your clutches while you are at it.
