Idle adjust on 02 SXViper?
eRent87
Chicago
Just purchased an 02 Viper with 5500 miles on it. The idle is really low, i believe its supposed to be in the 1800 range? Idles 800-1000, headlight dims and tach gauge and speedo even turn off sometimes for a few seconds. Hopefully its as simple as a couple screw adjustments? Let me know guys, thanks in advance.
Carbs might be dirty Pilots are prob. Plugged. Idle adjust screw is in top of the carbs. Flat head screwdriver for idle adjust.
I also suggest checking the read pedals. Mine were chipped and one was completely broke off. After I replaced them it started easier and idles perfect.
I too had the same problem with a Viper. Vforce junk! Put a set of OEM reeds in and problem solved!
