J
jaydougempire
Guest
Hey guys
I need fuel lines for my fuel pump. my jackshaft came apart and rubbed through them. Hesitant to use aftermarket lines. Anyone know the best place to get them? Dealer? Is there a fuel line kit i can buy to do the whole machine? Or maybe a couple rolls of the good stuff? Pretty sure they are metric and I don't want leaks! Any advice is apreciated!
Thanks mates
Jason
Thanks mates
Jason
take off your stock lines and measure how long all of them are together end to end. Go to your dealer and buy the line, they sell it by the foot, stick with oem if you dont want leaks!
J
jaydougempire
Guest
Ok 10/4 thanks
shaggyzr2
J
jaydougempire
Guest
Those are 7mm Id? These look pretty awesome do you have experience with them?
shaggyzr2
I've never used them, guys on here were talking about them last winter. I think they are 7mm od.
J
jaydougempire
Guest
Also...the leaky fuel line created a bit if a mist and my intake was sucking it through the foam seal. Turned the seal to slime. Any idea if I can just buy the foam seal and glue it Down? Don't wanna buy an airbox hahaI've never used them, guys on here were talking about them last winter. I think they are 7mm od.
shaggyzr2
You can buy just the foam. Last time I looked it was around $14
J
jaydougempire
Guest
Sweeeeeeeeeet thanks
