ET_nic
my other enticer 340 dont stop not dont start haha dont stop with the key and kill switch she always make spark and i dont find the wirring diagrame need help please thank you
nic
nic
all switches plugged in correctly with clean contacts?
ET_nic
I have double check all plug i dont know why she make this the engine runing good before is it the engine i have on my 80 enticer but i have put a 700 on it and the 340 is in a other enticer it is possible because bad ground i dont think she start i am confuse
the old sleds grounded the coils to shut them down like the tang on an old lawnmower to kill it on the spark plug.
ET_nic
Ils ok i have found a ground and i installe a other switch and now is ok but the kill switch dont work can i bypass the kill switch direc on the coil thank
should be able to.
