Anyone do this to their proaction sled? I hear they really help keep aluminum bars from soaking up all the heat....but what about steel bars?
roudyroy1
i did it to my sxr700 with stock bars. haven't gotten to try it but when i did a side by side comparison corked and not corked in 5c weather i noticed a difference with it just running in the garage
I don't suppose you could provide a link to the cork you used?
roudyroy1
Bought it from Canadian tire, it's gasket material. 1/16" I think.
A couple of bucks
Many auto parts stores carries rolled cork for gaskets.
Do an EBay search for.......1/32 or 1/16 cork sheet.
roudyroy1
It may have been 1/32, can't remember. Just get the thinnest possible.
I got a roll at Michaels,it's a store that sells crafts stuff,and I believe it's 1/16th but if you can get 1/32 get it because it'll be easier to get the grip back on with the thinner cork.
Guys that have done this. .. how well does it work?
roudyroy1
Wrap the cork on the bar tight with electrical tape, leaving a gap between each wrap, if you get the spacing right the grip will just slide over the cork with some soap and water but won't twist once the water drys.
roudyroy1
It also makes the grip a bit fatter, which i actually prefer.
Haven't had the opportunity to try it out yet,still waiting for snow.
