W arm rebuild
I have one of the bought re-enforced ones that maximum performance had when they were around. Just so happens to be out of the sled right now, I'll get pics tomorrow
When welding on a tube you should never weld across the middle of the tube of possible. Always try to weld on the radius...try to keep the weld joint corner to corner. Put the gussets inside the arm just the thickness of the gusset and weld on the corner of the tube.
I know that but I thought for the screwing around it would have been to weld inside the tube it was plenty strong enough with the flat bars on the opposing side.
