RE-jetting a new to me sled and not sure which is #1 cylinder??
Thank you
Thank you
PTO side is #1 on the 700MM.
Okay thanks, should I jet it different as per the book, or same as the other 2??
Devilin AblueDress!
Unless you have modifications that suggest a jetting change I would follow the book....or the "tech pages" here. Elevation/mods on sled dictate jetting, extra load/heat from clutch dictate richer jetting on #1 except on the Viper motors. Viper motor has less compression on #1 and is jetted the same on all 3 cylinders.
