anyone know what this piece is from or called 02 Viper with M10
snow7x
Canada
Just pick up a 02 viper last night with a M10 rear suspension, last owner didnt know what kind of sled suspension was out of, any way i found a broken mount/ bracket that bolts to the tunnel and holds the front suspension arm i guess you would call it in place.
Is this a viper part or did it come with the suspension? it looks re drilled to maybe also. here are some pics thanks!!
what it should look like
sled pic :P
M10 part, not a Viper part. Extra holes may be for adjustment or to fit different chassis, as opposed to re drilled.
Contacting FAST would likely answer any questions and source a new part.
This may not be your exact suspension, but similar:
http://www.teamfast.com/products/m10-ss/#/images/product/galleries/M10-SS/m10ss_med.jpg
Exactly it's a spacer/support to make up for the narrow front arm on the M10. Make a new one. It's only a piece of 6061 aluminum. use the good one for hole template. It can be made larger, depending on what you can find for billet aluminum.SRXtreme
