catt_tracker
I found a brand new 144 x 2.4 with 2.52 pitch Polaris track off a 2006 600.  Will it fit on my 2004 mtn viper?  Thanks, Ben
			Should but the height might give you some issues to work out
			catt_tracker
Ok Thanks
			catt_tracker
My new track just got here and the lugs are quite a bit taller than my factory track.  Does anyone know if it will fit or if I will need smaller drivers?  I hate to take it apart and not have the parts I need on hand to put it back together.  Thanks!!
		super1c
Super Moderator
If you bought a track with 2.4" lugs no it will not fit.   Not even sure dropping down to 7 tooth drivers it will fit.   What size lug did u get?
			catt_tracker
It's a 2.4" X 15 X 144 with 2.52 pitch
			catt_tracker
Not sure if matters but it's a 2004 mountain viper.  It has a 144 X 2 on it now I think.
		super1c
Super Moderator
Wasnt sure on how big a lug was oem. How much room do you have now with the 2" lugs?
catt_tracker
There is about 11/16" between the lug and the cooler.
			snoprokidf6
Run it. You will be fine.
			catt_tracker
Ok thanks.
			targa20
curious how this worked for you?
			catt_tracker
I'm waiting for the drivers to get here.  It was really close so I ordered some anti ratchet driver that are smaller.   I dropped down a tooth.
