I looking for info on max stud legnth i can use on a 1980 srx, i would like to 1.5" ice picks but have read on another fourm that the .875 is the limit.
I have the 8 tooth drive 2.52 pitch but I found on parts reloaded a 7 tooth drive with hex shaft spec that is 1/10" larger than my 8 tooth I'm sure with some shimming i could make it work.
I think yamaha bravo have 7 tooth on track drive i don't know how much tooth your have on your srx if you have 8 or 9 tooth a 7 tooth can be make the difference for longer stud correct me if i'm wrong
