s10mike
i am looking for a set of gears for my 01 sxr700. 39t/22b x 13w. would prefer to get the 70 link chain and gears as a set. but doesnt have to be. thanks guys
Backwoods M Max
check out ebay there is generally a bunch of part out parts on there. Be wary of used chains though, they may be overly stretched out.
A couple of bucks
My last chain I bought was through an A/Cs dealers Parts Unlimited catalog. They're way closer than the Yami dealer. It was a 13 wide 68 linker. I believe it also had the same stamping identification on each link as a Yamaha chain has. 50 or 60 bucks comes to mind. Remember it's the number of pins you need to count. Each pin= 1 link.
Backwoods M Max
The easy way to figure it out is gear teeth. 60 total teeth and under 68 links, 61 and over 70 links
How does the equation change with reverse?
Backwoods M Max
It doesn't. There's not enough difference with the reverse idler. I'm running 20/39 gears on a 68 link no problem. Dealer put a new 70 link chain on when it was still 21/39 and it used up all the slack in the adjuster.
