francis6667
did somebody has never put a phazer clutch on ex 440 and if yes what is the set-up
Throttle Junkie35
Im sure it has been done, but do you plan on not running oil injection?? The phazer doesnt have the pump gear on the back, if you didnt know.
Yamaha Nutz
yes we have done it ............phazer set up works good
francis6667
i will not run oil injection pump
francis6667
and wath would be exactly the best set-up
francis6667
bump bump
Yamaha Nutz
good set up is the 90 phazer set up ...87F weights and a yellow green spring
francis6667
thanks
