yamahaha
- Nov 24, 2003
Installing a set of pipes on this sled. Followed the instructions on how to install but can't figure out how the belly pan plate goes on. What pipes does it support. Does anyone have a picture of where it goes? Don't want to start drilling a bunch of holes above the shock tower till I know exactly where it should be mounted. Does it curve up or down, wide part to the front or back. Which pipes does it support? Any help would be greatly appreciated.
sleddineinar
Have you tried calling Bender? I have a 97 700 with Bender pipes, but it's 4 hours north of me, so I can't help you out right now.
DARV
Life Member
the metal plate goes on top of right side on top of shock tower. so the pipe doest burn a hole in the side panel.
