'97 700sx
MN_Yamaha
Minnesota
So, last year had a fuel leak. Fixed leak, then noticed I seemed to be going through more oil than normal. I had the sled serviced (cleaned carbs, checked specs, etc...) at a local shop. When we finally get enough snow around here, what should my fuel mileage be??? What should my oil consumption be??? I have had this sled for at least ten years, but until last year had not put on a lot of miles. Everything on it appears to be stock.
Thanks!
I would say between 10-15 mpg. I have 2 of these sleds one is about a quart/10 gallons of fuel. My other one went through 2 quarts/10 gallons of fuel. this one was new to us last year road it once. After I got home I noticed the oil cable was pulled apart under the rubber boot. By the carbs. Holding the oil pump fully open. i have not road it since waiting for snow so i can check that one again. Just something simple to check.
I was wondering the same thing, but for my 600xt what should I be expecting to get on mpg and oil? My sled has had a recent rebuild also so I don't know I the oil/fuel mixture, what is the stock setting for that?
Sent from my iPad using Tapatalk
