144 by 15 by 1.5 track?
norwegian
Well-known member
norway
144 by 15 by 1.5 is there such a track? for a 2001 MM I know you have to use 3 inch extensions?
Can the 3 inch extension thing snap off if you land on your tail, or is it almost as strong as stock?
thanks
for sure
There is atrack out there like that, and the extensions are rock soild. My buddy and i both run MM 700's with the stock 136 rails extended to 151, i think it is a 6.5'' extension and never had a problem, and we ride' em hard.
Going from 141 to 144 should only use about a 1.5" extension not 3". Haven't seen any 144 x 1.5 tracks but a lot of 144 x 1.25. I wonder when Camoplast will offer a fully clipped Ripsaw in 144 so can run extros.
