signs of weak clutch springs
mes882
iowa
Wondering if someone could tell me signs of a weak clutch springs. For the primary and secondary. Also how it would affect the rpms if the spring was weak in the secondary only? Then how it would affect the rpms if weak in the primary only?
Would this be correct.
Weak spring in either would cause an under rev. not an over rev.
In the primary low rpm engagement and low wot rpm.
secondary low wot rpm. with poor or no backshift.
