Hi guys, new here to the forum. had a question, just bought a 1998 srx 700 couple weeks ago. i notice a little bit of play on the secondary clutch. end up finding out the drive shaft sprocket nut in the gear box, im gonna be replacing the seals on the gear box and i notice theres no lock washer or lock collar behind the nut that holds the sprocket onto the drive shaft. im guessing i have to use some lock tight on the threads of the shaft? i also wanted to ask if theres a torque spec for the sprockets? thanks and hope to hear back
Kirk
Kirk
Yes, use lock tight on that lower sprocket bolt.
shaggyzr2
There is a washer behing the nut on the upper sprocket, torque for the nut is 43 ft lbs no loctite needed there. there is a bolt and washer for the bottom sprocket use loctite on the bolt, torque is 35 ft lbs.
Thank you for clarifying
, cant remember all this stuff at will any longer... getting old...LOLshaggyzr2
Thank you for clarifying, cant remember all this stuff at will any longer... getting old...LOL
I was just working on mine so I still had it in my head! ha ha
Right on..LOL
