profur03
Does anyone know what might be causing my enticer to be unsteerable when temp. drops below minus 15 ? the colder it is the worse it gets ,there is no snow or ice under the cab ,it is so bad you cannot turn the handle bars !
Thanks low slung, I will give that a try .In the picture is that a different machine or did you change to plastic skis ?
