01sxr700
We want to put reverse on my sons 03 sxviper mountain, will a '98 vmax 700 reverse chaincase work.
super1c
Super Moderator
any proaction reverse will work on any proaction! Say that 10 times fast. LOL. Only thing you need to watch for is the gearing may be different, and you cant mix the gears depending if they are hyvo or non hyvo. I dont know what year they changed between the two. Here is a post on a little info between the two if you arnt sure. http://www.totallyamaha.net/forums/threads/73449-hyvo-vs-non-hyvo Also do a search tons of info. But if you stick to all the same guts from one to the other you will be fine. Cover is the same as far as the revers covers.
01sxr700
So a 98 would be a non hyvo, how do you tell the difference?
