has anyone tried these in there srx or cpr piped viper and did you get good results? I have a set for my apex and was thinking about going with ulmer on that sled.
snoprokidf6
I have the primary kit which uses a different weight. Have gotten AWESOME results with them. Can't speak for the dragonfly weights but heelclicker makes a kick a** product!
I also have the 40/10s in my 2000 srx right now
I ran them in a friends srx he liked them
did u use randys set up and did u have to modify anything?I ran them in a friends srx he liked them
Ran spec of HC I dont know Randys setup
randy is the owner of hc.
I am going to order a set, with custom Yamaha primary spring.
A couple of bucks
Are the Primary,2-stage or dragon flys trail friendly?
From the design, I would say they will be trail friendly. You can easily change your engagement rpm in about a minute.
We added a little more heel wight
A couple of bucks
I didn't see an application for anything non-power valved.
I see, with the right helix and springs. My MM set up isn't near those in the instructions.
can u post how they come loaded when u get them
I think they come with all the washers and bolts and all in one bag, but if you want to see their inital set up, you can see it here:
http://heelclickerclutching.com/tech-info/pdf/DF-Pol-Yam.pdf
4,2 shoulder, 0 center, tip 3,2 overdrive 3,2.
thanks guys for the replies when we final get some snow ill do some testing
I'm not buying this for the overdrive bit, overdrive I can get with regular heelclickers. I'm buying this for the ease of changing engagement rpm. With the regular heelclickers, I have to get the washers to line up, so they won't hit the roller.
My buddy has them in his RX1 and work great, he won't let me try them in my srx but would like to know if there better in a drag race setup than the heel clickers
Let me know how they work thanks
never had a chance to try them this year put in tonys 8bu10 set up and never took them back out.My buddy has them in his RX1 and work great, he won't let me try them in my srx but would like to know if there better in a drag race setup than the heel clickers
