Hi guys. I have a 94 vmax 500. I want to put in a 600 motor from the same year. But it doesn't come with the primary clutch. I was looking at the parts diagram and it looks like the 500 and 600 use the same clutch weights and everything. I just wanted to confirm, are these clutches the same inside? Are the springs the same? What other differences am I missing?
What about the secondary? Are they the same on both machines? Or is the helix and spring different? Thanks.
01sxr700
Compare all the part no. on the micro fiche and if the no.'s are the same your good to go. and different no.'s you just have to order those parts or might be as cheap to find a used one. but then you never know about the condition.
