Have heard quite a bit of talk regarding guys running the 13 wide SX style gears in their 98-99 SRXs.  What can be gained by doing this?  I know the SX gears are cheaper, but are there other benefits?
			DoktorC
lighter...but not enough benefit for a trail sled..
			Thanks, Dok...just what I wanted to know.  I have a pretty full assortment of SRX gears, so I should be set...just wanted to make sure I wasn't missing trick of runnin the SX gears or something.
			SRXSRULE
- May 2, 2003
Anytime you can reduce rotating mass its a good thing. ===SRXSRULE===
			I understand that, but does it make enough difference to notice is basically what I'm trying to find out...thanks Eric!
			Junior
naa, couple hundredths, nothing a trail rider will miss
			HYVO vs non
You might want to check with some of the other GURU's on this but I think SX gears are non hyvo and SRX are hyvo. I believe the hyvo gears are a little more efficient and don't tend to allow the chain to "climb" as much under power. Just a thought.
Madmatt
Madmatt
yamaholic22
the srx gears are hyvo from 2000-2002 i believe, and before that they were the traditional silent chain type.
			Mtnviper
HYVO gears/chain are also stronger, and usually last longer too.
			yamaholic22
'98 and '99 SRX's dont have HYVO anyway, they are just 15 plate instead of 13, thats the only difference.
			SRXPete
I ran 700 SX chain and gears in my 00 SRX for a couple of seasons, along with 94 Vmax sliders, bender clutch kit, etc.  Acceleration was crazy, but lost out on top end since there were less teeth.  I think it was 22/37.  I took it out and went back to stock gearing for some more top end this year.  The SX gears will benefit a heavy rider imho.
