craigystylz
Just want to adjust the suspension a bit and did some reading on those rear tie bar? I dunno if that is the proper name. How do i get those washers off just unbolt it and take them off? And do i take them off from the top towards the front of the sled or bottom that is towards the back? Also does the limitier strap have predrilled holes or do i have to make new ones. I just want a bit more transfer and have the skis lift a bit?
Thanks guys
And i read throught that great thread about suspensions about 6 times lol phenomenal thread i think it was mr viper?
Thanks guys
I think your talking about the transfer rods.If I remember right when I adjusted mine I took them off from the bottom and then unscrewed the bolt that holds the spacers on.Its been a while I went to adjustables.
The limiter straps have existing holes in them. Tear into it you'll get it.
For your reference your previous readings are probably by betheviper he has writen alot on suspention setup.
