My girlfriend will be riding this sled..she weighs 130lbs.
I weigh 225. When I sit on the sled, the suspension goes half way down. This normal for my weight?!
I also notice the specs for the rear spring extended (installed) length has just one spec. What I mean by that is it doesn't give a soft length vs a stiff length. The front shock spring does have such a spec.
Thoughts?
Thoughts?
Throttle Junkie35
If it it is too stiff for her, adjust the shock accoringly. If you havent looked yet, there are two nuts the diameter of the shock that will need to be loosened to take pressure off the spring for a softer ride. You should have a spanner wrench in your tool kit to perform this adjustment, if you indeed still have the kit.
