Track Replacment Questions??
Jaysled
Webster, NY
Do you guys replace the jackshaft bearing when you are replacing the Track in your sleds? What about any other bearing/parts you would replace as preventative maintaince type parts. I have a 2001 Sxr 700 3200 miles.
just inspect all the bearings and make sure they all spin nice and free. For the sealed bearings, take the seals off, clean them good with brake cleaner, and repack with fresh grease, and put the seals back on, and they should be good to go. Obviously if any bearings are worn out, replace them now.
