V-Maximum
I have a brand new carb and plug it drives fine sometimes you need to use the choke to keep it running I checked all jets are clean. I don't understand why it won't idel keeps loosing gas and have to use the choke to get it to run
FJViper
Sounds like it's too lean at idle. May have to turn up the idle speed once you richen it up. What do you mean by "it keeps losing gas?"
V-Maximum
If you don't keep using the choke on and off it will cut offSounds like it's too lean at idle. May have to turn up the idle speed once you richen it up. What do you mean by "it keeps losing gas?"
V-Maximum
It will cut out as soon as you use the choke the engine comes to life squeeze the throdle and sometimes it will take right off and if it does not use the choke while it's running and it will take the gas and go ofcourse I only use the choke for a few seconds until it takes gas
check the crank seals and carb boot with brake cleaner or either. might have a small leak or a bad pulse line as well.
