How often do you guys clean powervalves?
justin1620
ON, Canada
Hey fellas..just as the title states, how often are you guys cleaning your powervalves. I use amsoil interceptor, and I used to clean them at the start of every winter. Last year my valves seemed pretty clean. I might start cleaning them every 2nd season. I also seem to rip at least one gasket while doing it. How often do you guys do your valves?
I run interceptor as well. I have 4 SRX's (and a Viper and SxR) so each one doesn't see a lot of miles per year. The more often you clean them the easier the actual cleaning is. I have a spare set of 700 valves and just swap them out and then take my sweet time cleaning them.
I don't believe I ever cleaned mine. I use that oil also. Maybe I'll check them. They looked good last time apart. I did spray carb cleaner on them but I don't think thats what you meant.
I would be pulling them out every pre-season at the minimum, no matter what oil I used, just to keep an eye on the condition of the valves.
