MADVIPER
Can someone please tell me the jetting specs for 98 srx 700. o deg and 1000 ft. I just looked at the pistons and they are clean. No wash, no color on the
top of the piston. Air box is stock, motor is stock. Only has the bender cold
air kit. thanks.
air kit. thanks.
I ran 148.8 148.8 150, but you might want to start with 150 mains and work down if needed. I personally did not like the cold air kit, so I taped off the holes and now can lean out the jetting a bit. I noticed no performance gains from the cold air kit, just more fuel consumption and noise.
