gitrdun
Anyone ever put a ripsaw onto a 136 Bravo? Used ones should be common, and I would think it would be an improvement but maybe it does not fit or work well?
toddmod
I put a 121"/ 1 & a 1/4 on my standard bravo, phaser 2 rear skid/ had to change drivers & extend tunnel. goes great! I'm sure you could put an 1&1/4 inch track on your 136. Direct bolt on? don't know
low slung
Last 10 years the BravoLT was produced they came with a .75 full block track(upgrade from the .510 prior)but I think this is the biggest you can go on the stock setup.
gitrdun
toddmod, is the Phaser 2 rear skid the same width at the mounting points, as the Bravo tunnel?
