Spikester26
Does anyone here have the torque spec for the primary clutch bolt? Any help is appreciated.
Throttle Junkie35
really tight.
Spikester26
Thanks for the help!
kenziesupra
Hopefully this works. Check out page 6-9 (thats 6 dash 9, not 6 thru 9)
http://www.pdf-archive.com/2011/08/09/lit-12618-01-21/lit-12618-01-21.pdf
its a really useful manual. SAVE IT before it's gone. hopefully you can access it.
Spikester26
Sweet! I got it, thank you!
Throttle Junkie35
Good save kenzie, I knew I saw the specs recently, but couldnt remember where. Honestly, I have pulled and installed a million clutches and never used a torque wrench. I just developed a good feel for what is tight. Although, if you are installing a comet on a yamaha, be sure to use the minimum required torque or you will have to cut the clutch off. I dont know why, but comets really are a bear to pull off Yami cranks.
