Reeds
Viktory2k1
Waukesha, Wisconsin
Since I have to pull carb rack for tors switch, I might as well replace the reeds. Is there any preference between boysen and v-force?
From what I've read here, there aren't any measurable performance gains with aftermarket and the V-force in particular don't seem to be as durable.
Having said that, I'm using Boyesen.
+1 ^^^
Stock reeds outlast any other, and no measurable performance gains going with aftermarket.
Edit: HOLY CRAP, I just did the math, I've been riding this sled for 18 years. lol, I have a problem letting go.
I should add that the only reason I installed the Boyesen's is because someone gave them to me. Didn't see any performance difference between them and OEM and I still have the OEMs which are still in good shape.
As far as Carbontechs are concerned:
1. Place a white piece of plain white printer paper on the table.
2. Put the reeds on the paper. They are made with the slightest bow in them. And I mean slight. The white paper against the black reeds makes this more noticeable.
3. Install with the hump(exaggerated)in the ^ up position. So that it always has a good seal.
