its the start of "heat checking". keep an eye on them as long as the cracks dont expand you can keep using the primary.
will it effect anything now? i mean the only time the belt is that low is when its idling correct? thanks for the quick response
YAMMIEGOD3:16
yes watch them closely, that can get larger and show up at the back. i had to replace two. also thats not the first one that had this happened. pretty common. 3:16 (yammie tony)
thanks again for the response, if they won't effect performance in the state they are in now, ill defiantly keep a close eye on them. I'm generally really good about replacing parts on my snowmobile. id rather spend the money now, instead of a lot more money in the future
