MiModRacer
I'm in the process of changing cranks on an 89 SRV & want to take the oil pump gear off in order to replace the inner seal on the PTO end. I assume I'll use a Clamp and a press to get the gear off but was wondering ?
1. Is their a raised stop on the crank end when pressing the gear back on so you know where to stop or ?
2. Should I put something like Loc tight Red on the mating surface W/the crank when reinstalling the gear ?
Any thoughts or experienced input would be appreciated... MMR
