Spikester26
Looking to put a clutch kit on a stock Exciter primary. Does anybody make one for these any more? If so who or what is the best kit o get for these machines?
Throttle Junkie35
No one makes anything for it anymore. There may be some out there tho. I like the silver/silver spring in mine. The yellow/ red is supposed to be a good spring too. A 49/39 helix pulls really hard. a lot of guys like the pink spring in the secondary, but I really like the white spring. You could always go to the new style clutch and use thunder shift or heavy hitter weights. Then you could use the 88r secondary.
TINK
Find a EXCITER II wide belt clutch and secondary for it. You will NOT be disappointed!
Spikester26
Thanks!
kenziesupra
If you're looking for clutching for the 88, check out hauckpowersportsinc.com. I got a clutch kit from them. Asked for aggressive kit and they ask about what setup it had and made the clutching to work the way I wanted. Got a great trail sled out of it. They were helpful as well. You can go this route if you don't want to spend time or money looking for other clutches. But I have to admit, the exciter II clutch setup is seemingly better than the exciter I. Too bad I don't own an exciter II or some clutches, only ridden a friend's 92.
