96 drive shaft
rubbersidedown
Plymouth Wisconsin
The square spring from the drive shaft to the spedo housing has broken off inside. It looks like the center of the drive shaft is removable. Is this the case. Is it regular or reverse thread? Or do you have any other suggestions? I have it soaking in penetrating oil now but so far it is not moving or the spring pieces coming out. Thanks Scott
I had the same problem with mine. The only way I could get the broken half out was to drill it out. There is an insert in the shaft that does come out, I think it's just pressed in there, part #8K4-47577-00-00. I never had to take one out but I heard some guys will turn a screw into it and pull it out with a claw hammer.
